bootstrap said:
You have a diesel. The operating characteristics are not the same. 6.0's are gonna need Rev's on certain hill climbs that the Dmax wont. And on steepish hill climbs, we are gonna slow down a little while you wont. Comes with the territory. So while you can use cruise just fine, on anything but flat ground it probably is a bad idea with a gasser while towing.
I'll chime in on this, as using CC and tow-haul is perfectly fine in both a diesel and gas-pot.
My '14 1500 with the 5.3L I used CC all the time, and had no issues or problems while towing my TT that weighs 8,500lb dry. I put on well over 15,000kms towing like that, I'd still have the 1500 if I didn't need a heavier truck for my TT. I also use my truck for work, when I traded my 1500 in she only had 28,000km on the odometer. I had a few issues with the truck, but it wasn't towing related.
The BCM, ECM, and TCM all work in rhythm with one another and talk with one another. If you're getting a hard shift, it generally means that a clutch is being applied exactly when a clutch has been released and you're getting a slamming feel. That is bad for your transmission, towing or not. A smooth seamless shift is when a clutch is applied and the clutch that is being released is still in use until the new clutch is 100% applied.
If your truck does that, CC and TH mode will not damage the transmission.
But, if you're worried. Don't do it.
