This seems to be a recurring issue/topic with many owners these days. This is my 2nd Vortec 5.3 since 2000. Bought a 1500 Sierra in 2000, put 349k on the clock before I sold it. Never had ANY major issues. Used Only synthetic oil (Pennzoil synthetic 5w30) every 3k miles. Never a sludge problem.
Bought a used 2005 Silverado 1500. 5.3L with 206k on the clock. Now has 279k. Uses a qt. oil every 2000 miles. Pulled valve covers, major sludge. Bore scoped oil pan, sludge. There IS. NOT a engine oil cleaner that will begin to touch this. Very simple solution, pull valve covers, remove all visible sludge until shiny clean. Remove intake, replace knock sensors, remove valley pan and remove all visible sludge until shiny clean. Now, remove oil pan, remove all sludge in pan until shiny clean. Remove pickup tube clean and install new proper "O'" ring. Thoroughly clean all surfaces when installing new gaskets. New filter, 6 qts. of Pennzoil Ultra Synthetic. Check for leaks. Replace filter after 500 miles. Change oil and filter at 1000 miles. I am VERY confident this will Eliminate the sludge issue permanently! All labor indicated can be accomplished in 8 hrs. with a laborer/helper.
For those out there that have a sludge problem you will be dumping bottle after bottle of engine cleaner and multiple multiple oil changes and still not get all the sludge out. Anyone that has work on the internals of an old engine knows how much solvent and elbow grease it takes to manually remove this crud
Comments welcome.
Comments welcome.
