#06-00-89-029M: Interior Cleaning - Instrument Panel (IP), Hard or Plastic Surfaces, Seats, Carpet, Leather, Vinyl, Fabric Cleaner, Stain Remover, Restorer - Product Availability - (Mar 2, 2016)
Subject: Interior Cleaning - Instrument Panel (IP), Hard or Plastic Surfaces, Seats, Carpet, Leather, Vinyl, Fabric Cleaner, Stain Remover, Restorer - Product Availability
Models: 2006-2017 GM Passenger Cars and Trucks (EXCLUDES Cadillac DTS Platinum and Escalade Platinum with RPO R9N - Tehama Leather)
Attention: This Bulletin also applies to any of the above models that may be Export vehicles.
This Bulletin has been revised to add the 2017 Model Year. Please discard Corporate Bulletin Number 06-00-89-029L.
To keep the vehicle interior looking the best, it should be cleaned often. It is important to keep the upholstery from becoming heavily soiled. The vehicle's interior can experience extreme heat, which can cause stains to set quickly. Lighter color interiors may require more frequent cleaning. Care should be taken because newspapers and garments may transfer color to the vehicle's interior.
Many of today's interiors are made with new low gloss materials. Permanent damage may result from using cleaners on ANY surfaces (interior trim, instrument panel, carpet, leather, vinyl and fabric) for which they are not intended. Using non-approved products can actually set the stain to the point that nothing can remove it.
Important:
Do not use silicone or wax-based products or those containing organic solvents (such as naptha, alcohol, etc.) to clean your vehicle's interior because they can alter the appearance by increasing the gloss in a non-uniform manner. The increase in gloss may cause annoying reflections in the windshield and even make it difficult to see through the windshield under certain conditions.
Never use a STIFF brush or a brush that has been previously used with a harsh chemical. This can cause damage to the vehicle's interior surfaces.
Use only mild, Neutral-pH cleaners. Avoid laundry detergents or dishwashing soaps with degreasers. Using too much soap will leave residue that leaves streaks and attracts dirt.
