My 2003 1500 HD has a leak in the cooling system. I took it to a shop and had a pressure test done which determined that the leak was coming from the weep hole. The mechanic recommended replacing multiple things as expected.
Replace:
I have a few questions about what are the right parts to get for my truck.
I was looking at the thermostats and noticed three different degree levels 160,185, and 187 which one would be the right fit?
There are a few different brands for water pumps any good recommendations?
How many hoses are used in the cooling system and what are they? (I replaced the heater hose where I thought the leak was coming from at first)
Replace:
- Water Pump
Thermostat
Upper Radiator Hose
Lower Radiator Hose
Serpentine Belt
Coolant
