So, I am doing my cam swap on my 2007.5 Silverado NNBS with a Gen 4, 5.3 LMG. I am also removing the AFM hardware. So I pulled out my old cam and inspected my cam bearings and noticed they had these odd marks on every bearing and only on the top portion (above the oiling holes), they do not appear to be worn and there is no visible copper. They do not really appear to be marks from damage but more machine marks but I could be wrong. The old cam is smooth as can be and has no visible marks on it. I had no plans to swap the bearings since the motor has a tad over 100k miles, it made no noises and had great oil pressure (45-50psi above 2k rpm and 25psi at hot idle). The marks all seem to be uniform and cover the full width of the bearings and do not differ. I talked to a motor tech at my local dealership and he said those are normal to aid in oiling. Are these marks normal or should I change them out?
