Pretty sure you win for the day!
If you have fish in the pond they are going to have a good time!Was looking for some epoxy paint to refresh my little 500 gallon pond and waterfall.. I'm comparing paints and I see these directions...
Why the hell would I waste my good vodka or everclear?
He was talking about the Epoxy sealer paint used for the garden. Using Vodka or Everclear for the thinner. (Alcohol abuse)That is a nice garden. Not dumb at all. Maybe mis-red the thread title?
Originally my parents house, they had hired an old guy to build it a long time ago. He was pretty old, so I did help him place the rocks, etc. I've had to repair it several times, replace the pump and redo the plumbing. I built the fence section..there was a cherry tree there, that's the reason it's a short section. The house you see in the background that looks close to my property line is my sister's house. I took down the tree last summer.That's nice man! Did you build it all yourself?
One of those guys that say fuel injection sucks! Carbs rule! I have to say that is the best carb conversion I have seen yet. Looks like a Ford Exploder 5.0l with the cam position sensor swapped to a distributor.File this under WTH?!
Think around here if you sell your house it's required to pump the septic. It's never good to have all that stuff above your septic opening. Luckily I have two 500 gallon tanks and that one only runs laundry basically.I just moved into a new place 2 years ago and it has a septic tank. When I bought the place the owner had no idea when it was pumped out last so I had it done before I moved in. They had landscaping and a bunch of stuff planted on top of the clean out and the pumper guy said that's a real bad idea. Plants like the water and fertilizer so they do good but the root system get's into the tank and clogs stuff up.
