1 - 3 of 3 Posts
Have an 01 2500. Currently going from stock duramax wheels with 265 75’s to 22x12 wheels with 305’s -44 offset.
my question is.. bear with me.
it is perfectly aligned to the stock wheels and tires. They wear perfect. Now adding these 22’s am I going to need a camber and or toe adjustment just from adding these?or should I just be fine swapping them out? I’ve been hearing a lot of mixed answers. Rather have first hand from others that have been doing it.
Appreciate any and all feedback. Thanks.
FWIW, over the span of a year I went from 18s to 22s and then down to 20s on my 07 1500 with the same alignment. Brought it to a shop that doesn't charge to rack and look, and stayed in alignment every time.
2015 High Country Duramax
You are definitely going to want to get your alignment at least checked with the much wider and much lower offset wheels.
You'll also need to keep an eye on your front end parts because 12 wides and low offset take a beating on the front end.
1 - 3 of 3 Posts
