1 - 4 of 4 Posts
Alright so some of you may have seen my post about getting nerf bars but thats out. I don't need them and prefer the look without them so my passengers can deal with it. With that said I'm considering new speakers front and rear for my 2011 EXT. Cab non bose and have no clue where to start. I got on crutchfield and found some that I thought would work but am unsure. I will be using stock everything just a speaker upgrade.
Fronts
http://www.crutchfield.com/p_575P167/Rockford-Fosgate-Punch-P1675.html
Rears
http://www.crutchfield.com/p_575P165/Rockford-Fosgate-Punch-P165.html
I have no clue if these will work or if there is better for the price. So any recommendations are welcomed.
IDK if the 6 3/4 will fit in the door panel might have to do some cutting to put them in... Does your truck have the tweeters in the door as well as the component? If it does then i would just get a component woofer insted of the 3 way. One of the best places to get audio gear for good prices would be http://www.onlinecarstereo.com/?gclid=C ... 4Aod9AgADA
Other than that i installed 4 6 1/2 POLK audio speakers in my truck. They sound good but need to have a small amp put on them, the sterio is a bit under powered.
IDK about the tweeters I think I read somewhere that they are in the a-pillars but I could be way off. I'll look into some 6 1/2 inch speakers. Crutchfield said those would fit with a bracket though so IDK.
I started out with the stock system and then my front speakers went out, I put 6 1/2 with the component set for mine. They were pioneers. That's what I also put in the back. I went all the way and put subs and amp and a new head unit. Everything I put in was Pioneer. Id go with 6 1/2 because when I installed mine they fit just perfect. They also sound GREAT! The Rockford fosgate is also a very great set but id get the component set that has the separate tweeter.
Heres the pioneer speakers I have: http://www.pioneerelectronics.com/PUSA/ ... /TS-A1604C
If you want to stick with Rockford Fosgate: http://www.crutchfield.com/p_575R165S/R ... tml?tp=106
That's just a suggestion to what I think speaker wise.
1 - 4 of 4 Posts
