1 - 9 of 9 Posts
I have a question about wiring two 5 channel Amps
I have multiple speakers locations
A pillar Components (independent crossover)
Kicker Midrange
Front Door Midbass
Rear Door Components (independent crossover)
two JL Audio 8W7
would it be a better idea to wire each side (left side/right side) independently, each 5 channel powers each side or should i wire it front/rear or more based on frequencies?
So you're running coaxial speakers in the rear? what are you going to use for your crossover?
If you're just going to use the amp's crossovers, use channels 3 and 4 for your midrange and misbass front speakers as those channels have a bandpass filter. use channels 1 and 2 for your tweeters and rear speakers.
Discussion Starter · #8 ·
I have coaxials in the rear now.
Right now the plan is to wire (1) 5-channel and run it as designed, 2 fronts, 2 rears, 1 sub. When I add the second amp, I branch the RCA to the second 5-channel run it as designed, but at a much lower frequency from the front components. So now I have another question, for a front stage imaging, can you expand more than a 4-way? I understand you can have different frequencies running to different drivers and woofers but is there to much overlay in this process. Any suggestions?
1 - 9 of 9 Posts
