That's my buddy's pulling truck. It's a 540 with something like 14:1 compression... it's pretty gnarly. Sounds amazing.
I realize we all take our risks and have our comfort levels....but those taller head rests in the front were specifically designed to protect from neck injury in the event of a rear collision. The support the head from flipping back. Some vehicles even have an active system that pushes the cushion forward in a collision so the head does not have to move back several inches before it is stopped by the headrest.woody01zf6 said:I also came to realization that most of the super annoying blind spots in this new extended cab vs my old regular cab was the head rests. So I took the rear head rests out and put them on the front, reducing the size of both. In GM's infinite wisdom, the stud spacing was different by 1.25in...but it's nothing a welder can't fix! Much better visibility now.
Explain to me how that argument would square with rear seat passenger protection, or does rear seat passenger head protection not count? Not only are the rear seat passenger headrests significantly smaller, but fully depressed into the seat back your head has no place to go except into the rear window glass. Fully extended from the seat back, which is only about 2 inches, the rear headrest would only impact your C1-6 Vertebrae, and the back of your head would still hit the rear window glass. What am I missing?nealinator said:but those taller head rests in the front were specifically designed to protect from neck injury in the event of a rear collision. The support the head from flipping back.
What would you rather have: No back head rest and your head go through the glass and your neck snaps or would you rather just have your head bang against the glass and probably end up with a head injury that could be non life threatening. Also rear seats are a hell of a lot safer than front seats so...roorancher said:Explain to me how that argument would square with rear seat passenger protection, or does rear seat passenger head protection not count? Not only are the rear seat passenger headrests significantly smaller, but fully depressed into the seat back your head has no place to go except into the rear window glass. Fully extended from the seat back, which is only about 2 inches, the rear headrest would only impact your C1-6 Vertebrae, and the back of your head would still hit the rear window glass. What am I missing?nealinator said:but those taller head rests in the front were specifically designed to protect from neck injury in the event of a rear collision. The support the head from flipping back.
I'm only 5'11", and at maximum extension, the rear seat headrests are still too low for me.shakenfake said:What would you rather have: No back head rest and your head go through the glass and your neck snaps or would you rather just have your head bang against the glass and probably end up with a head injury that could be non life threatening. Also rear seats are a hell of a lot safer than front seats so...
Where do they sit in relation to your neck? It's possible that since the glass is that close to you that the manufacturer doesn't feel it is necessary.roorancher said:I'm only 5'11", and at maximum extension, the rear seat headrests are still too low for me.shakenfake said:What would you rather have: No back head rest and your head go through the glass and your neck snaps or would you rather just have your head bang against the glass and probably end up with a head injury that could be non life threatening. Also rear seats are a hell of a lot safer than front seats so...
