110 Outlet
16K views 8 replies 9 participants last post by  Dragon
I was thinking that it would be pretty convenient to have a 110 outlet or two mounted in my truck bed for camping and tailgating. My question is has anyone done this and if so what would I need for this task?
Thanks!
At least one manufacturer has done this. I think it was only one recepticle and it had a weather proof door over it. My buddy's Rav4 (please forgive me for I have sinned) has an outlet in the back of the center console for the rear seat passengers. He has a switch on the dash to turn the inveter on and off.
For simplicity just install a 12V weather proofed outlet and use a standard off the shelf inverter. 12V would be handy if you need to use an air pump at the back of the truck.
I had a 110 V extension in an 09 Jeep Patriot.
It is one of their standard features.
It was placed below the center console in between the driver and passenger seats.
It came in real handy when you didn't have a car phone charger and only had a home charger. It also saved me on some road trips with the kids' portable DVD player.
This was really the only feature I liked about the vehicle.
I installed a 400 watt 12v/dc-110v/ac inverter in the truck dash slot that was fomerly occupied by a useless cassete tape deck. It's a Cobra inverter and it works very well. Keep in mind...unless you want to limit yourself to 150 watts, which is the max you can pull from a 12v cig/aux power port, then you will need to install some heavier wires. I already have a 700 watt stereo system with #4 power wires in the cab so the inverter is tapped into that. 400 watts will run lights and small stuff but not more than 3-4 amps in ac terms.
you could always take apart a power inverter and take the plug part out wire a cord to it keep the inverter inside the cab under your rear seat. Then run the wires from that to a outside rated outlet mounted under your bed or in one of the side holes in your bed then you hook a switch into your dash to provide a on/off switch for it. OK, so run on galore sue me lol I can make a diagram if it would make more sense to you but I was planning on doing it that way myself
