12v power into Cab 2017 Silverado
10K views 9 replies 5 participants last post by  Bhard
I just got my 2017 Silverado double cab lt z71 all star edition.
I am the deputy chief of my fire department and I want to put my radio, lights and siren in the truck.
My question is where is the best place to pull power from? I noticed that there is an extra pole on the battery but that is rated for 175 amp. The fuse box I am going to use is only rated for 100 amp. My plan is to run an 8 gauge wire through the grommet into the cab and under the rear seat through the kick panel.
My lights will be drawing hardly any power (I'm not going crazy lightning the thing up) the biggest draw will be when I use my radio and siren. But even those do not draw a lot of power.
If anyone has any tips I would love to hear them thanks.
The picture I attached is of the fuse box I have on the way.
Sent from my XT1585 using Tapatalk
Are you planning to have the power to your accessories always hot or only with ignition on/retained power accessories? If associated with key on, you can find a trigger wire for power relays in the junction box in the drivers footwell. The GM upfitter guide below has more information where power (5-10 amps) is available in the ICEM.
https://www.gmupfitter.com/files/media/ ... n_115c.pdf
If the 2014+ are like the older generations, the underhood fuse block will have a post for accessories. The max amps would be listed on the box cover. I would use that for the 8g wire if your accessories will draw less than that. My second choice would be directly to the battery terminal. If you go directly to the battery, I would want to place a large inline fuse within a foot of battery, similar to car audio power wires (in case a short happens between your distribution block and the battery).
You can pull power from the battery. On the NNBS trucks, there is a terminal outside the underhood fuse box that is hot 12v and you can tap in there. That is what I did on my 2013 and I used a fuse terminal block just like yours. You will want to put a fuse between the 12v source and the terminal block. I used a 30 amp and that should be plenty for most things even if you use the terminal block to power several items. But, you could use a fuse all the way up to 100 if that is what your box is rated for.
If you choose to use the MBEC for the power source, keep in mind the most you want to pull from that is 30 amps total. So if you potentially have more than 30 amps total being drawn from the fused terminal block at any one time, that won't be a good source for your 12V+.
@HorizontalHunter & esox07 as the writer of the GMT-900 guide that was linked to, I can tell you that the K2 "ICEM" doesn't have as high of amps available as the GMT-900 "MBEC". The GM Upfitter guide I linked to above has 2 x 5a, 1 x10a, and 1 x 15a. GM marked most of the upfitter pins as for use with a relay and not for direct power of accessories. I highly recommend following their instruction to avoid damaging sensitive electrical components like the BCM.
The guide for the older trucks does not apply.
I don't see a terminal on the fuse block, I will be putting in an in line fuse and just going directly off the battery then, the only thing that's on with the ignition will be the radio, but that has it's own fuse tap to a relay to turn it on and off but has constant power so can be used with the ignition being on.
Thanks for tips.
Remote head radio?
I don't check this page often enough but radio is actually what I do for a living (and occasionally full upfits). GM's are typically fairly straight forward. Power off the power distribution accessory lug under the hood and run pull ignition internally (I seem to remember a fuse labeled RAP inside the K2's).
I've actually got two power runs on my pickup (GMT900). One goes to the rear block from the battery) and powers the VHF radio, siren (which is actually a radio accessory) and is setup to also power a BDA but it's never been installed. The other comes off the underhood power distribution block and is currently hidden behind the dash. It's for an additional block to power the VHF control head as well as a UHF, 7/800 MHz radios and accessories (lights, portable battery chargers). Except for the VHF stuff, nothing else is currently installed (planned in the next couple of months though).
