Thanks for the replies, I was running a Summit 8701 cam in the 4.8 with LS6 springs, planning in the same with the 5.3, so it's not the nastiest build, I do beat it hard sometimes, and it does see the odd heavy load, still gets used as a truck, and it may see more power someday but who knows, it seems like the Sonnax parts to build a strong 4L60 are expensive enough, which is OK, but I question if maybe 4L80 would do the same job for less, maybe just a rebuild, valvebody upgrade and slightly higher stall convertor vs a complete performance build, I also feel like a 60vs80 is like a TH350vsTH400 in that the smaller trans take less power to turn, and the 60 has the higher overdrive, so would there be an advantage to the 60 for economy, and power loss, I'm a mechanic and do my own tuning so other than driveshaft fab I can do the labour with the cost of my time, drag racing against a similar truck, one with an 80 and the other with a 60, would a 60 have a lower ET? This is what keeps up at night
