AC hot drivers side
1.5K views 3 replies 3 participants last post by  05Canuck
05 silverado 1500 z71 crew cab dual electronic climate control
When I turn on the AC, passenger side is cold while drivers side is hot. After a few on off cycles, it then switched to the drivers side being cold and passenger side hot.
To fix this issue, I recalibrated the climate control. Here is a link on how to do so https://www.youtube.com/watch?v=WWnjTwI ... ture=share
Hope this helps someone out there
If it comes back....check into replacing the blend door actuators. Very common failure on that model....and older ones too.
The good thing is the drivers actuator is a breeze, the passengers, however is another story. Drivers under the hush panel, the passenger side one is buried behind the radio. I think they built the entire truck around it! I was able to recalibrate mine with a cycle similar to the youtube link you provided. It saves a lot of skinned knuckles for sure.
