AFM delete kit
2.7K views 18 replies 8 participants last post by  plotthound
Ive got a 2015 gmc sierra 5.3 and would like to pull all the afm crap out and chuck it in the garbage. What kind if a job is it to do this for a semi handy old fat guy?also what is the best kit to use? Thanks
Texas speed has everything you'd need, as do other places. You can go with a stock profile cam or get something a little better.
It's a bit more involved on the LT based ecotec motors than it is on the LS motors, but it's not too bad if your comfortable with internal engine work.
Basically the heads need to come off, and front cover, and timing chain needs to be removed. You'll need to pull the radiator out and the grill to get the cam out. I've heard of guys dropping the crossmember out and being able to disconnect driveshafts and motor mounts and tip the engine up and a hard angle and do it, but that requires and engine crane and jack. I don't think that's how I'd do it, but I've heard it can be done.
Personally I'd rather just pull the rad pack and grill.
All depends on the shop and area, and if they charge by a flat rate or by the hour.
I believe book time is around 30 hours labor. So if they charge book time, that's around what it'd be at whatever hourly rate they get.
It doesn't take 30 hours for a good tech though. You do need a lot more parts, and more labor on the ecotec motors though. Just because more needs to come apart compared to the vortec motors.
I just did this on my 2015 LT. I used a kit from Brian Tooley Racing. Great kit and they were tons of help when I had questions. I highly recommend BTR. After removing the timing cover I found that the oil pump couldn't be removed without dropping the oil pan. So timing chain was tricky but can be done with patience. I lapped valves and new valve seals. Radiator is easy to remove and good time to replace a/c since it's a pain to get to otherwise. Diablo tuner is the way to go in my opinion. The job is worth the trouble and expense. Makes a difference. Good luck.
the reason i started this thread is because we have the exact same truck as mine at work,that has suffered afm failure.it only has 104,000 km on it and as lifter failure.$2200 bux later it was back on the road for a day then had another lifter fail.my own truck has had a range device on it almost from day one and im at 84,000 km.i dont want to go through that buisness since i use my truck in some pretty remote areas and am not good at walking anymore. cheers
also the truck at work never made any long trips or had the afm disabled.its only been use in town where i imagine it went in and out of v4 and v8 mode constantly.it did however have regular oil changes at the quick lube.not sure if switching to a high end oil like amsoil would hae saved it. i use kirkland brand oil in my own changed about once a year because of the low km's i put on it.but am considering going to amsoil with all our vehicles.anyhow im going to call around to a few shops and see if anyone specializes in this kind of work.im not going to tackle this myself.
#16 ·
The AFM lifters are still in your engine and are still prone to failure. Tuning AFM off could reduce the chances of a failure, but it won't eliminate the risk. And 25 HP from a tune is highly unlikely.
parts and fluids to do it yourself 1500 or less.
For a shop to do it I have seen 2500-4000 quotes, depends on state/area it seems. Lot of good shops more competitive and cheaper, just one or two in a large area probably more expensive.
so after reading tons and tons of posts and info on this subject here is what im going to do.will continue to use my range afm delete device and not do the recomended 10,000 km oil change.truck will get the oil changed twice a year even if i only put 2000 km on it in 6 months.will also continue to use kirkland signature 0w-20 oil.my truck is basically parked in a heated garage for the winter and not driven.if i have an issue with the afm,will deal with it at that time. cheers
#18 ·
If you park it for the winter, I would suggest just doing 1 oil change annually, just before you park it. Fresh clean oil doesn't go bad just sitting there, it's old, used oil that's more of a problem sitting in the engine for extended periods of time.
