So I've been having this ongoing issue for awhile now. Truck is a 2011 Silverado z71 has 99k on it. It's more of a rattle when hitting sharp or big bumps. It can be felt in the steering wheel and in the floorboards. Also slight vibration in steering at 45mph and above. Definitely sounds like it's coming from both sides of the front end. Something is moving that shouldn't be. It sounds like a bad front strut. But the whole strut assemblies are both new. I even changed the the quick struts again to make sure it wasn't them. No luck. There is absolutely no play in any of the front end components. I've checked it several times and I also took it to front end shop and they checked it as well. Came up empty handed. I thought it was possibly a bad upper control arm bushing but the shop is a good reputable front end shop. They said upper control arm bushings were good. Usually when a hub goes bad you either get play in them or the notorious grinding or whirring noise which changes when you turn one way or the other. I have neither of those. I've read on a few different sights of people having similar symptoms as me with no play or hub noise and they changed the hubs and it fixed it. Whatcha all think? Anyone ever had similar hub bearing problem without the usual hub bearing signs?
