My diff is good. Just changed rear u joint this week. Front u joint done last year. Tranny is good and fluid is good. Why is it still clunking going into reverse?
Like I said, you dont know until you have checked it this time. The is a remarkable increase in the number oc crappy aftermarket parts. Just because you looked at something a little while ago doesnt mean iis still good. Also, unless you had your diff apart and used a dial indicator to check iit out, then you cant know the diff is good.BlackKnightGhost said:Gonna have to check the clip yokes out. Haven't checked them yet. I know for sure everything else is fine.
