I have the following information from the Chevrolet VIN Decoder. I'm trying to figure out which number determines my gear ratio. I'm assuming it is 3.42, or does the min or max number represent the ratio?
This is from the decoder:
Axle Ratio
1) - Rear 3.42, 3.73, 3.23 3.23 min 3.73 max
Other transmission info from decoder:
Trans Order Code MYC, M30
Trans Type 6, 4 4.0 min 6.0 max
Trans Description Cont. Automatic w/OD
First Gear Ratio
1) 4.03, 3.06 3.06 min 4.03 max
Second Gear Ratio
1) 2.36, 1.63 1.63 min 2.36 max
Third Gear Ratio
1) 1.53, 1.00 1.0 min 1.53 max
Fourth Gear Ratio
1) 1.15, 0.70 0.7 min 1.15 max
Fifth Gear Ratio
1) 0.85 0.85 min 0.85 max
Sixth Gear Ratio
1) 0.67 0.67 min 0.67 max
Reverse Ratio
1) 3.06, 2.29 2.29 min 3.06 max
Axle Ratio
First Gear Ratio
Second Gear Ratio
Third Gear Ratio
Fourth Gear Ratio
Fifth Gear Ratio
Sixth Gear Ratio
Reverse Ratio
