Does my truck look leveled?
1.4K views 13 replies 8 participants last post by  easydoesit
New to the site...just a quick question.
Attached is a picture of my 2009 Silverado Z71. It came from the factory with the 265/70/17 tires. Parked next to similar year Z71's it looks higher. I can't imagine the previous owner lifting it, being that he only put 27,500 miles on it in six years, but I could be wrong....what do you all think?
Here is one at the side view. Also the measurement from the ground to the fender is 39 3/32" in the back, and 38 7/8" in the front so it has almost no rake to it.
No strut blocks, already looked for that. Maybe the torsion keys are cranked in? It doesn't ride rough at all though. The struts look stock, but the truck was so clean when I bought it that it would be hard to tell stock from aftermarket. It was an old man's trade-in on a 2015. Only 27,500 miles and garage kept so there isn't much wear on anything.
StoneColdZ71 said:
Just take a tape measure and get the measurements for the front and rear that might be more accurate! just my two cents.
I mentioned the measurements above, but I'm not sure what baseline is. Currently it is 39 3/32" in the back and 38 7/8" in the front
There's definitely some sort of leveling kit/device. The fronts are normally in the 36'ish range. What type of shocks do you have? If they are Bilstein's, there's your answer (if they are the 5100's).
