GM/AC Delco PF63 filter
14K views 29 replies 16 participants last post by  Pierre009
Hi,
trying to buy some PF63 oil filters (mine is a 2024 1500 5.3L with engine) as per the maintenance manual...cannot find any source. Tried local shops like Autozone, O'reilleys and 2 GMC / Chevy dealers but nobody has any. Amazon has the PF63s but when entering the vehicle specs to verify fitment, the warning comes back saying that this filter does not fit my vehicle??? I am trying to stay OE for now, I know I can get get equivalent quality filters from other brands. Thanks.
#29 ·
I think I read an article that stated there is a difference between the PF63 and The PF63E. Oil bypass pressure is higher on the PF63E to accommodate the higher oil bypass pressure newer engine were designed for. If you use the Reg PF63 in engines that has the higher oil by pressure spec, the PH63 might be bypass oil through due to it its lower pressure design.
