How do I tell if a have a 6L80-E or a 6L90E transmission?
77K views 15 replies 11 participants last post by  RedSLEd
How do I tell if a have a 6L80-E or a 6L90E transmission? I've looked in my build codes and can't see any thing that tells me. Where do I look next?
I'd get in touch with the dealership or if u get in touch with GM Customer Service on this forum. GM Customer Service was able to PM my built list from my vin number. It showed EVERYTHING installed on my truck from the factory. Start with them, they should be able to lead u in the right way.
Sent from AutoGuide.com App
Trans is NOT designated in a light truck VIN....
Digits:
1 - 3 World Make Identifier
4 - GVWR/Brake System/Body Style
5 - 6 Line/Chassis/Series
7 - Restraint System
8 - Engine Type
9 - Check digit
10 - Model year
11 - Plant
12 - 17 - Production serial number
GM if your monitoring this site
Trying to decide what to buy -- Truck will be optioned for trailer towing, if 1/2 ton it will have the 9 3/4 in ring gear & 7.3 something rear axle ratio -- Not sure about 3/4 ton specifications
What transmission comes in a 2014 1/2 ton gas Silverado with the trailer towing option -- 5.3 & 6.2 Ecotec3 engine
Would the transmission be different if the trailer towing option was not chosen
I am interested in the same information if it were a 2014 3/4 ton gas Silverado 2500HD
Will the transmissions offered in the GMC trucks be the same as the Chevrolet
I guess easier said, what are all the possible transmission available for the 1/2 & 3/4 ton Chevy & GMC trucks.
Thanks in advance
I am not GM but I can answer the questions. Only 3 transmission used in 2014 trucks as described below.
Yes
Max Trailering Package, includes 9.76" rear axle, (GT4) 3.73 rear axle ratio, (JL1) trailer brake controller, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs and increased RGAWR
1 - Includes (G80) heavy-duty automatic locking rear differential and Z82 Trailering Package. Requires (L83) 5.3L EcoTec3 V8 engine. Includes (PZX) 18" x 8.5" bright-machined aluminum wheels with (RBX/RBW) 18" tires or may upgrade to (RD4) 20" aluminum wheels with either (RC7) or (QSS) 20" tires.
2 - With (L83) 5.3L EcoTec3 V8 engine, requires (PZX) 18" x 8.5" aluminum wheels and (RBX/RBW) 18" tires or may upgrade to (RD2) 20" chrome wheels with either (RC7) or (QSS) 20" tires. With (L86) 6.2L EcoTec3 V8 engine, requires (RD2) 20" chrome wheels with (QSS) 20" tires. Not available with (Z71) Off-Road Suspension Package.
RPO MYC 6L80 HD 6-sp
No
RPO MYD 6L90
Yes, identical in all respects mechanically, appearance and creature comforts are only difference between the brands
Only 3 transmission in use...
6L80 1500
6L90 2500, 2500 gas engines
Allison 1000 2500, 2500 Diesel engines only
MYC - (1500) Transmission, 6-speed automatic, electronically controlled with overdrive and tow/haul mode. Includes Cruise Grade Braking and Powertrain Grade Braking
MYD - (2500,3500) Transmission, 6-speed automatic, heavy-duty, electronically controlled with overdrive and tow/haul mode. Includes Cruise Grade Braking and Powertrain Grade Braking
1 - Requires (L96) Vortec 6.0L V8 SFI engine or (LC8) 6.0L V8 SFI Gaseous engine
MW7 - (2500,3500) Transmission, Allison 1000 6-speed automatic, electronically controlled with overdrive, electronic engine grade braking and tow/haul mode
1 - Requires (LML) Duramax 6.6L Turbo Diesel V8 engine.
These options require an LT or LTZ trim level, double or crew cabs only
1/2 ton trucks come with a 6L80E transmission. IMHAO, the 1500 with a towing package will tow a decent amount and should be sufficient for most people but, experience with lighter transmissions show they aren't meant to tow heavy loads for long periods. 3/4 & 1 ton trucks come with a 6L90E transmission. Both the 3/4 & 1 ton come with either a 3.73 or a 4.11 gear altho the 1 tons usually have just the 4.11 gears as they are rated to tow more. (10K for 3/4 ton and up to 30K for diesels) The heavier trucks have a 14 bolt floating axle ratcheting type of differential called a "Gov-lock" positraction.
Again, IMHAO, if you are planning on towing a lot, get the heavier trucks. If you tow a boat of small trailers now and then, the 1/2 ton would work as long as you don't try and tow more than you really should. (Be honest here)
