Largest Spare Tire
17K views 4 replies 4 participants last post by  schrutemanager
Just doing some research with my truck, lift, and tire size
What is the largest tire size that will still fit in the stock spare mount and area?
Close to stock, maybe a 33" class, depending on OEM size. Hence a lot of lifted truck owners running 33's or bigger drop the spare altogether to save weight. If you ran 33's, and had a stock spare, it would be like a donut and not technically that safe to run for very long, if at all. A 35" tire will definitely not fit underneath the truck.
I finally have larger tires installed on my truck, 295/65R18 = 33.10 x 11.80
I need to get a close sized matching spare...........for the 17" spare wheel
Spare P265/70R17 = 31.60 x 10.40
Again, the spare tire width does not concern me, just trying to get close to the 33.10" diameter
Finding a common size 17" tire for a spare is also a concern
275/75/R17 = 33.20 x 10.80 (Tire Rack say does not exist)
33 x 11.50R17 does not exist
33 x 10.50R17 size does exist, but only one make/model
Other option is to find a used 18" rim on Ebay ? (but that will also be $200 ontop of still needing a tire)
255/75R17 = 32.10 x 10
too small
255/80R17 = 33.10 x 10
right fit diameter
Toyo sells an open country in the 255/80R17 for $215
I think this will be my cheapest and best option
