Leaking power steering fluid
29K views 10 replies 4 participants last post by  starspangled6.0
The Silverado is leaking power steering fluid, as of today. I saw a nice wet spot on the driver side frame, and sure enough, it's dripping wet from right under the brake reservoir. Looks like there's 2 gaskets on it, and it's wet underneath both of them. My guess is it's the middle one that's leaking, but I wiped off the whole thing with de-greaser so we'll see what it's like in the morning. Any tips before I replace them? It doesn't look too difficult, but who knows. I took some pics for your viewing pleasure...
Any idea for a part number? I couldn't find anything at rockauto.com.
:cry: so you think I have to do the whole unit?
So no one has the gasket... maybe the stealership has one, but I'm not dealing with those morons. I'll probably build my own... looks simple enough. It's cardboard-based, nothing fancy.
So apparently there is no gasket... just some sort of internal leak that requires full hydroboost replacement. Roughly $250 for the whole project... wish me luck :)
Update:
Took me a while, but I got it done yesterday, or so I thought. It still leaks the same amount or worse then before. The steering is better, since you have to do a full fluid flush, but it's still peeing like crazy. I'll tackle it again tomorrow; hopefully it's a bad hose, and not something in the hydro-boost unit. That thing is a royal pain to get off the firewall!
Victory! We found it was one of the high-pressure lines leaking at the HB unit. Looks like the o-ring had totally disintegrated. That was probably the whole cause of the leak, but since the HB unit is prone to leaks a lot anyways, I'm happy.
