Can someone tell me the normal oil pressure ranges I should be experiencing. 103k. Valvoline high mileage 5w 30w. Napa gold filter. Little bigger than stock. Thanks.
That's good pressure, it will be fine.sparkplug said:tell me if mine is normal, 45 at cold start, 40-41 at hot idle, 43-45 while cruising.
That seems high... Even floored I've never seen mine go over 50.tex50 said:I get 60 cold idle to 70 running cold. 40-45 warm idle to 60 running warm. Idle seems consistent to your numbers but upper end seems high. Good or bad?
You have a variable displacement oil pump, read up on it.2018 5.3 nearly pegs the 80psi guage under WOT. Assuming the guage isn't correct. Gonna put the scan tool on it asap
Thanks for the snark. Never heard of that. Who knew?You have a variable displacement oil pump, read up on it.
That wasn't my intent, had to abbreviate my sentence and then clean up after the dog.Thanks for the snark. Never heard of that. Who knew?
Mine runs at 750rpm 22psi then at 1500rpms 30 to 35 psi, above 2000k rpm 40 psi. You will get valve noise anything below 20 trust me had a oring on my pick up tube go out you thought it was about to throw a rod. Mine truck gauge on the cluster is off so hooked up a wet gauge shows the truth but gauge on the cluster was showing below the 20 mark like 15 psi or damn near zero. So say the stepper motor is bad cause when you unhook oil sending unit the needle is showing on the bottom where it says oil. But short answer is 20psi at idle is good for the 5.3Can someone tell me the normal oil pressure ranges I should be experiencing. 103k. Valvoline high mileage 5w 30w. Napa gold filter. Little bigger than stock. Thanks.
