Hi Guys,
I have a 2008 GMC Sierra HD 4x4 with the 6.0 V8 Gasser in it. It has low oil pressure at idle. I have done all the tests, mechanical gauge, pressure sending unit, etc. I think it is the oil pickup tube oring is torn. Causing aeration and low oil pressure at idle and when I rev the engine it gains oil pressure. I picked this truck up and plan on flipping it so I am putting minimal time and money into it.
My question is:
Can I replace the oil pickup tube oring without tearing apart the pump, harmonic balancer all that. Just by squeezing in through the drooped down oil pan. Also will I have enough room to get at this by just dropping the pan down and not fully off so I will not have to remove the differential?
Thanks
My question is:
Thanks
