Day-0 Monday
A couple hundred miles ago, my all-stock 1999 Silverado SES dash light came on. Only one code, P0161, both "pending" and "saved". P0161 is O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2). I erased the codes back then. SES has not come back on in the last few hundred miles.
I need to re-register my truck this month, so today I checked if the emission monitors had completed. 3 are not: cat, evap, and egr. Also there a pending P0161 and no other codes. I do not know how long it has been pending, and the SES light is not on. I'm hoping the P0161 is causing the monitors to not complete.
I unplugged the passenger side post-cat O2 sensor at the frame rail and found with a multi meter that the heater element has 5ohms, and the pink and the black wires on the harness side are at battery voltage with key-on. So It seems the heater element is fine and it is getting juice. Not sure what to check next. I could remove and swap two sensors, clear the codes and see what codes comes back, but that doesn't seem promising given the test results. Any suggestions?
