I was leaving work a few hours ago and right before I started my truck I noticed the brake light in the cluster looked like it was very dimly illuminated. It went full brightness when I started the truck, like normal, then when it would normally turn back off, it stayed dimly lit. Like I'm talking very dim. I probably wouldnt even be able to see it in the day time. It still comes on brightly when I set the parking brake, so the bulb should be fine. It also STAYS ON once I turn the truck off. I got home and let it sit for about an hour, and went check it, and its still on after the truck has been off for a while.
So is there a ground I need to check somewhere or something? I'm about to start my V8 swap in my Miata and it will be down for some time, so I need my truck to not crap out on me.
Truck is a 2007 Silverado Classic with the 4.8L with drums on the rear.
