I've mentioned some of these issues before but the most common problems seem to be overlooked. Almost every time something arises it is labeled AFM problem. Hopefully this will have a bit more explanation and give some something to consider. Granted the AFM lifters are not as robust as you would hope for so taking care of them would seem to be a top priority. From what I see other problems magnify weak points. Many things seem to be taken for granted. The biggest ignored problem I see is the PCV system itself. IMO it is a complete disaster and cause of most of the "AFM" problems. And the reason many still see oil consumption with AFM off. The AFM system may at times contribute to more oil vapor but what is causing it to be sucked into the combustion chamber? The vapor also should be minimized on the 2011 + years with the cap over the vent, yet still reports come in with oil consumption. The PCV is constantly introducing moisture to the crankcase and single biggest problem I see causing oil consumption, not AFM. You have a constantly open 10mm intake tube from the engine. The constant flow through a 10mm tube that is just to large and introduces moisture as well as fresh oxygen which is corrosive in itself. If the crankcase is not sealed it will pull even more volume as well as unfiltered unmetered air. Basically this system is contaminating the engine, oil intake valves and cylinders. But it seems everyone is focused on AFM and the idea of AFM. Basically the idea is sound. Not the best idea, I think there is a better way but there is no reason that a closed cylinder would have any problems if its not in taking and firing. Its only springing back and forth without combustion. In many ways you might think the AFM rings would last even longer. There is no reason for it to cause problems with the rings or anything else. The only problem I have seen with that is the oil drain holes are to small in the pistons. Combine that with dirty oil with contaminants from long OCI with constant addition of moisture and oxygen and its a recipe for a problem. Combine all of this, mix it up put it in a lifter and you have more problems especially with a weaker AFM or DOD lifter. Catch cans are a great addition to help keep this out of the combustion chamber but your crankcase is still contaminated. Everyone talks about how the fixes have not fixed the problem. This is because they are only minor issues while the real problem is never addressed. The single biggest problem IMO with these engine is the irresponsible PCV system. Put a smaller tube on it or even a PCV valve and see if that doesn't help the issue. Make sure the engine is sealed. Clean out the baffles in the valve cover. If you want more vacuum on the engine reduce the intake tube side, just be sure the engine is sealed. And check your spark plug gaps. This will compound the problem fouling plugs when burning oil. It will not burn a good mixture well if the heat isn't right. The gap affects the resistance, arc length and the amount of current it can carry therefore the heat and rate of combustion.
Something to consider.
