I have a slight problem with my 98 Sierra. I can have the coolant recovery reservoir filled to its appropriate level, drive around a bit, and it seems that when I put the vehicle in park, then back into gear, I have coolant spray out all over the engine on the drivers side. Once the reservoir is empty ( seems to take a while, maybe a couple weeks), I have no more leaks or problems, and the coolant level will remain right below the connection shown in the pictures. I believe the line I'm showing in the picture is the transmission cooler line? (It's the lower metal line)
Anyone had this problem before, or know what could be the problem? I'm thinking there could be a crack at this location? Does that line get pressurized as the engine warms up?
