The Quest for Auxiliary Input on a Factory Delco Radio
It started with a simple idea. Something almost every aftermarket head unit (HU), and probably most new HU's have standard. Auxiliary
sound input. So I started the google search!
I found some tutorials on how to modify the factory HU to tap into the CD player audio channels and bypass them into a 3.5mm jack. So I scavenged a 3.5mm jack from an old PC board and added some wires. Red for Right Channel, Gray for Left Channel, Black, for Ground. This was intended for testing so it wasn't a beautiful job by any means....
The first tutorial sounded just about perfect, EXCEPT it required a CD to be playing, to allow for the bypass to work. I wasn't really thrilled about wearing out the CD player, so I continued my search. I found another tutorial which was a similar bypass as the first, except it claimed to disable the CD player and retain auxiliary input, PERFECT (
https://ls1tech.com/forums/stereo-elect ... ethod.html)
First a few pics of my bench setup and wiring. Rear of the factory Delco HU
Snipped end from an ATX power supply from a PC. Square style Molex pin, fits into the pins very nicely for bench testing. I put some
loose shrink tube over these to avoid shorts.
Here is the head unit with the necessary leads. Power, Ground (coming from ATX PSU), left/right audio channels. Used some stripped wire insulation on the other bare pins to also protect from shorting anything.
Power and Ground alligators clipped on. Ground has green boot/black wire, and 12v has yellow boot/red wire.
Powered up!
So I cracked open the Delco radio to investigate, and test if the aux bypass with disabled CD would work.
Here is the radio opened up from the bottom side. Comes apart easily by removing 7 screws.
This shows the 2 wires for left/right audio that come from the CD player built into the head unit. I probed them with sewing pins and wrapped wire around to see if these were correct (they were).
Here is what the work bench ended up looking like. Wiring info in the picture.
From here I attempted to copy the tutorial and cut 1 wire from the CD player harness (bundle of white wires) to see if that would disable the player and allow an auxiliary audio source. Unfortunately the head unit from the tutorial was different, and I knew it going in that the wire may be incorrect but I gave it a shot. Didn't work, so I gave up on this idea and didn't want to cut a bunch of wires to guess which one might work. I fixed the wire and put the head unit back together, and searched for another method.
Then I found where some people were doing a very similar mod, except with the slave unit (CD/Cassette deck) which looked more viable to me. My truck came with the center console and Cassette deck, so I was good to go to test this one. (link:
https://www.gmfullsize.com/threads/hoor ... re.106394/ )
Here is the victim. OEM Delco Cassette tape deck
Now this was easier to test out disabling wires because I had a separate harness that I could remove the pins from and plug and play!
The end goal was still to have auxiliary in, and NOT have extra mechanical devices moving. Cassette decks are actually fairly loud, little motors whirring away so I was going to see if it was possible to disable it and keep auxiliary sound. To bypass the audio signals from the cassette deck is trivial, but to disable the tape player and keep aux in was not documented anywhere that I found.
Here is the pin out, schematic, wiring diagram for the remote slave unit. This info was copied from another source with slightly different wiring colors, but likely the same thing. Probably just different years/make/model of GM that account for the variation.
Here is how I set it up for bench testing. I used loose heatshrink tubes to cover the pins and keep them separated while testing.
I determined a method to disable the Cassette deck, and allow for auxiliary sound to work, by disconnecting the dark green and pink wires in order. I needed to be able to reconnect both of these wires in a toggle fashion, so I decided to try a DPST switch. There was a slight concern that the switch wouldn't work because while I was bench testing one wire had to be disabled before the other, and I wasn't sure if both being disabled simultaneously would work. I ordered some cheap switches from ebay to test it out.
Here is the cassette moved into the truck for final testing and wiring. The switch was hooked up temporarily for testing and it worked, I was very pleased
Here is the "final" wiring, everything heatshrinked and soldered. I extended the wiring for the DPST switch so it can be mounted somewhere. The test 3.5mm jack is still being used, but if I find a place to hard mount a jack I will buy one that can be permanently installed and redo that end. I capped off the audio wires from the cassette side and left them in the connector so technically I could splice everything back together as factory and have a working cassette again.
Will put together a video for the auxiliary input mod above also, but it's super easy and you should be able to tell from the pictures how to accomplish it. Basically it is taking the 3 wires for audio, Left/Right channels and Ground and going to your audio jack of choice. Then you break the pink/green wires which interrupts the Cassette deck from playing, but the head unit doesn't realize it and you can continue to play from your aux source. The only downfall is you need to have a cassette in the player and it will have to start playing for a few seconds to initialize it, then it can be disabled. Also the aux in source will not persist between key on/off (except for maybe during retained accessory power) so you have to toggle the switch each time you start the vehicle. Not a big deal though in my opinion.
You probably noticed part of my floor console is missing. That was a serious pain lol. I will have a video and a few pics of that up at some point. I am planning some mods to that portion of the console, so it is removed for now...
