2013 Silverado 2500HD
There is a slight stumble/sputter during idle every 3 to 8 seconds, the tach drops 100-200 RPM and the engine shakes/shimmies a little bit.
Sometimes this happens right when I hit the throttle, and I can feel it sputter a bit before full power comes back.
So far, I’ve replaced the plugs, wires, cleaned the MAF and cleaned out the throttle body. I also just replaced a broken exhaust manifold bolt, which I thought maybe was causing this, but apparently not.
I’ve also ran some injector cleaner through the tank, and will run a few more. The next thing I will try is to reset the throttle position sensor, since some people have said that this fixes it, but wondering what else it could possibly be?
