softer ride
1 reading
7.8K views 11 replies 7 participants last post by  shakenfake
Hey everyone. I wanted to post a question about getting a softer ride out of my truck. I have a 2011 GMC sierra 1500 single cab work truck. Bought it used a few years ago and it's always been a rough ride. It does have aftermarket rims and tires, 275,60,20's. The front is stock while the rear has lowering brackets but not all the way level. Considering buying a lowering kit that would include new springs but I actually like the way it sits now. Would buying a softer set of springs front and back work? If so, what should I be getting? Any opinions/suggestions?
thanks,
Robert
^^^^ my first thought, too. ;)
What type of tires? Bad ball joints can give a rough ride. Bad shocks?
wow, that is way too low. you should be closer to 35-40 psi. something has to be wrong if it really has that bad of a ride with those pressures.
if there is no clunking or symptoms of bad parts, I would look at shocks. the rancho 9000 adjustable seem to provide a soft comfortable ride according to those that run them
if that still doesn't get the ride to where you want it, dropping to 17 or 18 inch wheel would help. but you should still run the right pressure. you can have unsafe handling and bad wear by running your tires that low
I've only been running them like that for the last few weeks. It helped but it feels more like a suspension issue than tires. Just feels like there is no suspension, me, seat and tires. I had an alignment done a year or so ago and the mechanic said that the shocks look new, bilstiens. could it be that since it's classified as a work truck the suspension is stiffer? It's a short bed single cab so there's not as much weight as a double cab?
5navarro said:
...... getting a softer ride out of my truck. ... It does have aftermarket rims and tires, 275,60,20's. The front is stock while the rear has lowering brackets ....
So, the truck has aftermarket wheels and tires, plus the suspension has been modded, which means the Pandora's Box of various ride-quality issues has been opened. Perhaps there are additional mods that have been done, which you are not aware of. It might be worth trying to contact the person who did the mods and at least finding out what was done. Maybe the springs were changed, maybe this, maybe that, who knows?
At this point, you're playing a guessing game. I always recommend taking it slow and easy, with small changes to see what the results are. Tire pressure is certainly an interesting comment. I've never heard anyone running that low of pressures, plus I'm surprised your TPMS isn't warning you.
Anyway, my first change would be to a set of stock shocks. Next I would probably do wheels & tires. I would buy 18" wheels. You can find a set of brand new GMC takeoffs on eBay for $500 or $600, then get a nice set of easy-riding street tires.
If you want to do something on the ultra-cheap & easy, add a few bags of sand in the box, a couple hundred pounds worth.
At that low of air pressure, you're going to wear-out the outer edges of your tire tread really quickly. I run my Michelin 275/60/20's at 38 psi. My truck rides great.
