Ticking Sound, Crack on Exhaust Manifold, Possible Exhaust Leak
2.2K views 9 replies 5 participants last post by  Back in Black
Hey y'all
I have been chasing down an intermittent tick that was showing up coming from the passenger side of the engine under load not at idle. I have only heard it in the cabin and it never got much about a faint tick, maybe a click.
At first I thought it was something in the coolant system as I had a leak in my radiator and thought there may be air bubbles, so I fixed all that. Tick kept showing up, but it has been getting quieter. The other day at idle I noticed a few times I could smell an exhaust leak in the cabin so I checked the exhaust and found a little crack in my exhaust manifold on the passenger side.
Pictures are below - the pink/purple color is an additional LED on my lamp
Would this make sense for the source of the ticking sound? I am wondering how serious this is as I've never had this happen before.
To give additional context, when I did the knock sensors recently I also put on a new intake manifold (Dorman...) and it is a little bigger than the OEM.. does anyone that have been the cause of this happening?
Any advice is very appreciated thanks yall
The manifolds on my L96's and LY6 are all like that, with a split in the middle of both exhaust manifolds, and I'm pretty sure it's the same on the LQ4 as well. All oem manifolds.
Same here on my ly6
I don't believe they are through-holes, but IDK for sure. If it was a through-hole and the bolt was missing, you would know it immediately, if the bolt is broken off, then I don't think it would leak past the bolt (I've got at least 2 of those shield bolts broken off on my LQ4).
It's possible the exhaust bolts have worked themselves loose, for the LY6 I recently put in my '12 3500, the seller of the truck the engine is from noted it had a tick, and that turned out to be just loose exhaust manifold bolts.
You might re-torque your bolts, using the sequence/torque indicated on charm.li (website) for your truck and see if that helps.
Otherwise, a mechanics stethoscope might be useful for narrowing down where the sound is coming from.
A tick caused by an exhaust manifold is usually loudest on cold crank but gets quieter or even goes away once the motor warms up. I think you would need to take the shields off to find any cracks in the manifold. Stethoscope is a great idea, but if you don't have one a long screwdriver touching the exhaust and pressed to your ear does exactly the same thing. Even a piece of wood or a broom handle will work if you don't have a stethoscope. I promise it works. Try it.
