transmission fluid
6.9K views 9 replies 4 participants last post by  oldmachinist
hi my i was wondering if my Manual Transmission had (Low Gear, RPO M W3) or (without
Low Gear, RPO MG5). how do i know? my transmission serial number is 03 06 03 G3? i dont know what fluid to use. its a 2003 chevy 1500 silverado single cab with a 4.3 v6 vortec with 4 wheel drive. thanks colin
Theres the drain and fill bolts at the back of the tranny. theres also a big bolt on the very bottom that when you removie it it has the bolt with it hollow in the middle and it has a long spring in it, and it has a metal sleve that looks like a bullet and its hollow inside. and i dont remeber the order when i took it out im not sure if it goes bolt, spring, sleeve? or if it goes bolt, sleve spring it could work either way?
