Transmission won't shift in Manual Mode.
1 reading
23K views 6 replies 3 participants last post by  350_Malibu
2500HD, 8.1. crew cab long box. 2007. 88400km. Truck works fine in drive shifts properly, when i select manual mode stays in 6th gear on dash but i fell it shifting. Any ideas on what it could be. I live 1.5 hours from nearest dealer. Also the tow button on gear selector does not work either. Thanks for any help.
Also have a 2003 1500 4.8 283000km. tow selector does not work on that one either.
My 2013 does this too, it's normal I pretty sure. Try putting it in M2 and see if it only shifts once to second. It should hold second, but still take off in 1st. In M6 it should still shift through the range of gears. Think about it, if it tried to start off in 6th gear while in M6 you'd be burning that trans up in short order.
when i put it in M it stays in 6 on dash display, the transmission shifts throught the gears i just cant select which gear i want. I was told by Chev dealer that if i put it in 4th it will up shift and down shift up and down by it self.
