21 - 40 of 74 Posts
Discussion starter · #23 ·
im not familiar with all the bose system setups that gm has done over the years. the only research i did was on the 09 year truck but im sure that all the new body style gm trucks are the same. if the amp looks any thing like the picture then it should be the same. but if you only have 2 plugs i have no clue on how it is wired or how it works. sorry
is there anyway to tell if you have the luxury or normal system? i have a 2013 silverado ltz ext cab full load except sunroof and rear entertainment and my bose system sounds great, but if im missing out i want to know lol
Discussion starter · #26 ·
If you read the beginning of the post. I put the pictures of the luxury amp vs the Bose non luxury amp.
I believe only Cadillac and Denali are the only one with luxury Bose amp
Discussion starter · #28 ·
No I'm not making any harnesses . I have way too much stuff going on too many projects that have been started but all need to be finished.lol
If you look at the first post there is a link at the bottom . It will take you to my other post showing you how to make your own.
The first post also talks about the difference between the lux and standard amp.
Lux amp is pretty much a computer that controls all you factory stuff.
Discussion starter · #36 ·
^^^^^^^ AOEM-GM24. ?
Well this write up is for NNBS 07-13 trucks . Older trucks I am not familiar with and that adapter is for older trucks .
It's not that I have anything against older trucks. I just don't happen to own one to know about the system.
One thing that this mod does it eliminates the Bose amp out of the system completely
As you turn up the volume the factory Bose amplifier lowers your bass output to protect the factory speakers.
So when you tap into the system with an adapter after the Bose amplifier the amp is still killing your bass output.
Kudo's on figuring out how to get this working and making up your own harness to boot! I have a question maybe you (or someone) can answer for me sort of along the lines of what you did. I am considering building a box, adding an AMP, and wiring everything up to my factory NAV head unit. I have some decent Polk Audio speakers I am replacing for the factory ones and would liketo add a little power to these as well. So I was thinking a decent 5ch AMP should do the trick. So my questions would be:
1. Most AMPs I've seen have a sub input but obviously the factory head unit doesn't have a SUB output. Can I find an AMP that will take the LOW level inputs from the front and rear out of the HU and use an internal crossover to output to the sub?
2. Recommended amp for this?
Discussion starter · #40 ·
Hi whippled496
Sorry it took so long for me to reply I have not been on this site for a while.
Every amp manufacture has different set ups for there amps. If you happen to buy a 5 channel amp. Most can run off of just 1 set of RCA's but you won't have front rear control.
But if you run both sets you front and rear you will have control of front rear . On most 5 channel amps running a sub input is taken care of internally so you don't need that 3rd set of RCA's
Most amps now at days have built in crossovers taking care of the sound signal.
I used a 4 channel amp for my mids and highs both set of RCA's going into my amp.
But my amp has RCA outputs.
It sends the rear signal output to my sub amp as a sub signal .every manufacture makes their stuff different so just look at the specs before you buy.
I won't say which brand to buy cause everyone has their favorite brand . But with car audio you get what you pay for.
My system has been going strong daily abuse since 1999. This set of amps and speakers were in my other car then installed in this truck. The only thing replaced were the rear door speakers.
But you always can add an audiocontrol in dash eq or crossover with volume control that will give you all 3 RCA's .
I did have one before and loved it. Sold it
21 - 40 of 74 Posts
