Im having a problem with my audio system where there is a whine coming through the speakers that follows the engine RPM. I recently put in new door and pillar speakers and an amp for those speakers. How could I fix this problem?
Check the ground on your amp. You've probably just got a shitty connection. I would start with the amp. And don't double ground two components to the same point.Alternator whine is the granddaddy of car stereo noise. The most common and the most annoying. Alternator whine will be heard as a high pitched whine that will rise and fall with the engine speed. Most of the time this is caused by a poorly chosen ground for a piece of equipment.
