Window Switch.. or motor..?
16K views 8 replies 5 participants last post by  tcnoakes
My driver's side window no longer works. When you press the window switch, you can hear the relay clicking, but the window does not move. This happened before, but would work if i lightly hit the door with my fist. Now it does not work at all. I want to say it is the switch and or relay that is bad, but I know it could also be the motor. The motor has not been slow or stuttered at all, so that is why I am asking the hive here with your thoughts on what you would think it is.
Thanks in advance.
^^^ Bypass the switch to power motor is a good way to test the motor, be carfull and apply power to the correct wire. I would lean towards the motor or loose connection before switch as you said when you hit the switch you hear a click. That click means the switch is doing something.
yeah id bet its a bad connection or failing motor. found out previous owner of my truck has had 2 replaced. at least with an 09 youre less at risk to have your power locks fail. I have one that's not working and one thats intermittent, and its only a $280 fix each!
