41 - 60 of 102 Posts
Ive no info on the others, but there is definitely a fix for the crank / no start condition.
Update was released Nov 2021.
John Barta has explained the cause and correction in a interview.
I've experienced the same issue on my 2020 1500 LT Trail Boss. Dealer could not find codes so released the truck. One common theme with my truck is the issue presents itself when the steering is under some type of load. Example, towing my camper (3300lbs) and going over uneven road surface will often trigger the issue or when off road clearing large obstacles (driving over big loose rocks). The steering has always returned but it is dangerous, especially when towing a camper. Last week I was returning from a trip and experienced another steering failure; however, it has now been three days. I've tried maintenance on earth straps (suggested fix) but no dice. I really wish GM would solve this issue. The dealer charged me for the last diagnosis, so I'm trying my best to troubleshoot myself.
Well, I've just been informed by my dealer that I require a new power steering rack at a cost of $4800 (taxes included). Pretty disappointed as this issue was known whilst it was under warranty but they couldn't locate it. Now I'm out of warranty...
If you have the receipts from when you complained about the problem while it was still under warranty, you should be able to get GM to cover it.
Reactions: JonSilver
I have a 2020 Trail Boss, Replaced the battery and now the Service ESC and Traction Control light are on as well as service Power Steering. I have unhooked the neg battery cable multiple times from 15min to 8 hours and still nothing. Any help would be AWESOME! Thanks
I have a 2020 1500 with the Duramax 3.0L ... Doing exactly the same thing... It has the same issue where the main screen does not always come on and just got the same power steering issue. Seems like something is wrong with the computer on these trucks... It's currently in the dealership.... They have had it 2 weeks...
I just wanted to reach out to say Thank You to @loud_pipes and all of you who posted on this issue. My husband and I had this experience last night, after traveling across country for more than 13 hours with delayed connecting flights. We got back to the truck after a week away and just wanted to get home. In our case the truck wouldn't start - click, dead battery. Fortunately the parking lot where we stayed had a battery charger and were able to give us a jump. The truck started but the instrument panel lit up with all kinds of issues: this plus the Check Engine light. It was midnight, we had been traveling all day, and we still had an hour and a half drive ahead of us. This message board bailed us out of a sucky situation. The 20 minute turn off and restart trick helped and we made it home by 2:30 am. Thank you all for sharing your experiences and your tricks. Really helped us out so much.
My truck is currently in the shop for the same issues. Power steering and pinion replaced but now they are saying that the it is getting no communication to the computer and “module not supported” GMTAC is being of no help to the service department. Seems as if they don’t know where the issue is stemming from or how to fix. Has anyone had any luck with getting their truck back and functioning properly???
2020 GMC AT4, 5.3L, 10-speed, 32k miles. I was on a trip in early May, 5 hours from home. Bad timing for an electrical problem. I've never had a problem before, the truck has been perfect. I had just driven about 550 miles in the previous 1.5 days. We stop for dinner, come out and start my truck. The Service Power Steering and Service ESC light up the dash like a Christmas tree. Driving with no electric steer is both difficult and dangerous. But I limped it about 2 miles to our hotel and jumped on the forums. Sadly, GM-Trucks.com has an 11 page thread about this issue in 2019-2020 GM's. So strange, but the solution was to wait 20 minutes and restart the truck. I did that (it was more like a half hour) and sure enough, it worked perfectly again. Strangest damn thing I have ever experienced with a vehicle. Upsetting. That was at 30k miles (yes, I put 2k on in about 4 weeks). It has not recurred. I don'k know what happened, whether it downloaded its own software patch, "rebooted," or reset in some way, but it self-resolved (at least for now). According to others, some dealerships are saying they've never heard of such a thing, others are saying they've heard it but not seen it. It seems like one of those things that is common enough to be concerned, but not so common that a TSB was issued or a recall exists. I still don't have a good answer as to what happened, but am throwing this out there in case anyone else experiences it. Sent from my iPad using Tapatalk Pro
I had this same issue on my 2023 silverado however the issue was continuous and the dealership was unable to diagnsosis the failure. They tried some stuff but in the end I had to have the vehicle replaced
2021 5.3 V8 crew cab w/AF.M disabled by factory. 14 mon5s old 38k miles Power Steering needs service esc disabled. same problem as everyone here% parked the car in the evening in the morning no power steering.no esc Dealer backed up, no loaner cars available.
2021 trailboss and I had a similar issue the problem would come and go as I drove. I pulled the negative from battery for 20 mins and that did nothing. While putting the cover on I noticed the B terminal on the battery was loose. I tightened the bolt back on and the issue instantly went away. Two days now without an issue and I believe I solved it. Hope this helps someone
Absolutely. I was so unprepared for it the first time that it didn't even cross my mind. But if it happens again, I'll grab video for sure.
i just had the same thing this morning. i turned it off went in the house, got my husband he came out turned it on and backed out of the driveway and it was fine. i had no problems getting to work. strange
This happened to me today. 2024 Silverado 875 miles. Have had it for 2 weeks. Getting steering column lock, engine light, ABS light, traction control light. Went from a Ford to this POS Chevy. So lame.
Your 2024 truck is nothing like the 2020 of the OP. Your truck is under warranty, no doubt.
Did you join the forum just to read thru old posts, find similarities and vent, or do you have a question/issue and would like help?
I joined to see if there’s any solutions to this issue which looks very common from what I can tell and does carry into 2024 so GM obviously has not fixed the issue. Yes I did vent because this is not what I’d expect from a new vehicle with 875 miles and driven for 2 weeks. Very disappointing. Do you have any solutions?
